Pumpa za gorivo?
+17
ricpe
Bokara
baki001
jugi
dejank.
seljak
zokisa96
marex
medo_kv
21 posters
Strana 4 od 4
Strana 4 od 4 • 1, 2, 3, 4
Re: Pumpa za gorivo?
I was looking at a regulator for my Ford pickup, and it may be exactly what you need here. It's made by Malpassi, and called a Filter King. It amounts to a sediment bowl and filter built into the bottom of a fuel pressure regulator. Some models have a provision for a delivery pressure gauge. They seem to be very popular in Europe, but not many places here in the US carry them. You may have good luck finding them in your area.
As to your gas leakage with the original fuel pump, I had the exact same problem. The plastic ring between the two diaphragms has a pair of vent holes to normalize atmospheric pressure in the dead space between the two diaphragms. Unfortunately, I can't just go down to the parts store and buy a mechanical pump for a Yugo. I had to order one from a company in Texas, and it is currently in the mail. For the time being, I put a pair of wood screws in the vent holes. That is enough to run a little bit for testing, or moving the car around in the shop. I have an oil change planned very soon, so I am not worried about a little gas in the oil. I can always throw it in the tank of my tractor along with a little more gas and get some use out of the fuel.
heviarti- OHV 767ccm 30ks
- Broj poruka : 114
Lokacija : Emmett, Idaho USA
Datum upisa : 11.06.2017
Da li na motoru 1300 2007. god. moze umesto pumpe sa pogonom na polugu moze da se ugradi pumpa sa pogonom na osovinicu?
baki001- OHV 767ccm 30ks
- Broj poruka : 102
Datum upisa : 28.10.2012
Hvala!
- Broj poruka : 102
Koliko se primeti povecanje ulja u motoru na mernoj sipci kada benzin probije u karter?
I sta u tom slucaju curi iz one rupice na pumpi za gorivo ulje ili benzin?
strelok89- OHV 903ccm 45ks
- Broj poruka : 426
Datum upisa : 24.02.2018
Zavisi koliko probije, ali definitivno nije dobro kad probije jer se ulje razlaze od benzina... Nisam siguran na koju rupicu tacno mislis, nisam drzao tu pumpu u ruci jedno 2 godine
- Broj poruka : 426
I kada probije benzin u karter sta se pojavi na rupici toj ulje ili gorivo?YUgisa ::Iznad membrane je benzin, ispod je ulje.
Hocu da znam kada je vreme za zamenu da se ne desi mesanje ulja i benzina.
- Broj poruka : 426
Iskreno nisam nikad rastavljao te pumpe pa ne znam kako je unutra sklopljeno, kad predjes na EFI onda mi se javi Ali mozes testirati lako benzinsku pumpu, zatvoris izlaz a na ulaz stavis parce creva i odseces ventil sa unutrasnje gume od tomosa ili auto gume i stavis u crevo i onda uzmes lepo kompresor i gurnes 0.5 bara i vidis jel ce da gubi pritisak.
Baci to smeće, uzmi električnu pumpu i reši se bede zauvek.
Većina električnih nema membranu, radi po sistemu rotacione pumpe. Znači, ili radi, ili ne radi (crkao motor u njoj)...Što mnogo pojednostavljuje celu situaciju.
d.stole- OHV 1295ccm 61ks
- Broj poruka : 612
» El.pumpa za gorivo
» Florida 1,3 in problem pumpa za gorivo
» Pumpa za gorivo
» pumpa za gorivo
» Pumpa za gorivo
» Pumpa za gorivo
» pumpa za gorivo
» Pumpa za gorivo
Strana 4 od 4
