Karburator 30 MGV 1 i 30 MGV 10 (Fica)
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Empty Karburator 30 MGV 1 i 30 MGV 10 (Fica)
Počalji od ZAC Sub 07 Dec 2013, 19:41
Sredio sam neke karburatore...dva tipa 30MGV1 i 30MGV10..oba karburatora su namenjena za Zastavu 850 i imaju difuzor od 21 mm.
Evo malo slicica pa uzivajte.. Very Happy
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Aoj1
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Igno
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Fo98
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Bmza
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Vtuw
Karburator 30 MGV 1 i 30 MGV 10 (Fica) 5hix
Karburator 30 MGV 1 i 30 MGV 10 (Fica) 2map
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Vru8
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Ypkq
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Wsqs
Karburator 30 MGV 1 i 30 MGV 10 (Fica) 3tcs
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Ucb9
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Ifnc
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Zlog
Karburator 30 MGV 1 i 30 MGV 10 (Fica) A8fo
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Tyix
Karburator 30 MGV 1 i 30 MGV 10 (Fica) 5ptn
Karburator 30 MGV 1 i 30 MGV 10 (Fica) K2q7
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Gq5m
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Empty Re: Karburator 30 MGV 1 i 30 MGV 10 (Fica)
Počalji od nenad_jj Sub 07 Dec 2013, 19:53
Svaka čast ZAC. Ko novo. Smile
Broj poruka : 228
Lokacija : Ivanjica
Datum upisa : 06.12.2012
Počalji od ZAC Sub 07 Dec 2013, 19:56
Hvala... Wink
Počalji od nenad_jj Sub 07 Dec 2013, 19:59
Moram meni na yugu 45 da sređujem karb. Izgleda da mi dosta srče goriva. Primeniću tvoju metodu Wink
Broj poruka : 228
Lokacija : Ivanjica
Počalji od ZAC Sub 08 Feb 2014, 23:47
Jos jedan IPM 30 MGV 10  Very Happy
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_99357_CAM00102_122_371loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_99363_CAM00104_122_546loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_99375_CAM00105_122_137loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_99381_CAM00106_122_469lo
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_99387_CAM00108_122_344loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_99392_CAM00110_122_191loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_99398_CAM00113_122_13lo
Počalji od ZAC Sre 10 Dec 2014, 22:16
Odradjen jos jedan 30MGV10 dif. 21mm
Ociscen u ultrazvucnoj kadi, obrusene nalezuce povrsine, zamenjen mesac (stari je pukao) , dihtung lonceta i gumice dizni.
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37053_CAM02254_122_539loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37055_CAM02250_122_1096loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37056_CAM02251_122_223loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37058_CAM02252_122_98lo
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37060_CAM02253_122_401loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37061_CAM02255_122_155lo
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37181_CAM02275_122_343loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37183_CAM02276_122_425loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37185_CAM02277_122_253loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37187_CAM02278_122_215lo
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_37188_CAM02279_122_479lo
Počalji od ristivoje Sre 10 Dec 2014, 22:32
Čika zac,može jedno pitanje? Smile
Broj poruka : 2226
Počalji od ZAC Sre 10 Dec 2014, 22:41
Pitaj brale. Smile
Počalji od ristivoje Sre 10 Dec 2014, 22:44
Brale:) Pošto vidim da je kod tebe ravnjanje karba obavezno,kako to izvodiš?
Broj poruka : 2226
Počalji od ZAC Sre 10 Dec 2014, 22:45
Brusenjem na ravnoj povrsini.
Počalji od ristivoje Sre 10 Dec 2014, 22:51
Ko pita ne skita:) Nisam bio precizan,one bakarne cevčice,jel vadiš?
Broj poruka : 2226
Počalji od ZAC Sre 10 Dec 2014, 23:17
Naravno... pa kako bi drugacije obrusio povrsine..
PS_ i nisu bakarne vec mesingane cevcice.. Wink
Počalji od ristivoje Čet 11 Dec 2014, 06:50
Jedno mislim,drugo kažem Smile Čini mi se da je na onom glavnom odlivku krivo tamo gde naleže na kućište leptira,hteo sam da čupam al ne mere. Mogu da ti dam da se zabavljaš Very Happy
Broj poruka : 2226
Počalji od ZAC Čet 18 Dec 2014, 23:38
Jos jedan IPM 30MGV10 (Fica) Difuzor 21mm.
Ovaj je na prodaju.
Karburator je generalno sredjen...vidi se na slikama.
Cena.... 5000 din.
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_40470_CAM02305_122_515loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_40472_CAM02306_122_852loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_40474_CAM02307_122_549loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_40476_CAM02308_122_910lo
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_40478_CAM02309_122_173loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_40479_CAM02310_122_55loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_40481_CAM02311_122_45lo
Karburator 30 MGV 1 i 30 MGV 10 (Fica) Th_33254_CAM02312_122_78loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_33255_CAM02313_122_39loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_33257_CAM02314_122_75loKarburator 30 MGV 1 i 30 MGV 10 (Fica) Th_33260_CAM02315_122_196lo
