Kakvih sve bisera ima...
Kakvih sve bisera ima... Empty Kakvih sve bisera ima...
Počalji od Pedja Sre 04 Nov 2009, 10:04
Nisam imao ideju gde da postavim, a mislim i da zasluzuje posebnu temu...
http://www.mustangforums.com/forum/5-0l-general-discussion/368307-im-done-with-this-car.html
My car was idling like crap the other day so I figured since I just got it, it may have been awhile since anyone changed the oil out. I decided to go ahead and change the oil. I used Mobile 1 synthentic oil like I was reccomended on here. Anyways, I drain out the oil and noticed it was extremely dark and even after 10 minutes of draining, it was still coming out. I decided to go ahead and flush it to make sure all the bad stuff got out. I hooked up the hose, ran water through the engine, started it up and was waiting for the water to come out clean (The engine never went above idle so I was told this would be ok). Anyways, About 3 minutes into this, then engine starts shaking and shuts off. I figured it was all cleaned out so I plugged it up, added the oil and figured I was ready to go. WRONG! The car won't freaking start now. This car has been nothing but trouble for me, I think I am done with it.
Ispirati motor vodom... Doh Laughing
SOHC 1116ccm EFI 63ks
Broj poruka : 1848
Lokacija : Zrenjanin-Novi Sad
https://zafc.forumsr.com
Kakvih sve bisera ima... Empty Re: Kakvih sve bisera ima...
Počalji od DRAZEN92 Sre 04 Nov 2009, 10:35
YOU REALLY ARE A MORON. Laughing
Budala....
DRAZEN92
DRAZEN92
Broj poruka : 793
Lokacija : Subotica (Djurdjin)
Datum upisa : 11.01.2009
https://www.facebook.com/drazen.dulic
Počalji od flash_back Čet 05 Nov 2009, 13:59
ahahah Very Happy boze budaletine Laughing
dobro mu je ovaj prvi odgovorio:
YOU REALLY ARE A MORON. CONSIDER TAKING MASS TRANSIT!!!
YOU CAN NOT RUN WATER THROUGH THE CRANKCASE OF AN ENGINE. IT IS NOW SEIZED UP AND WILL NEED REPLACING. PLEASE FIND ANOTHER HOBBY BECAUSE YOU SUCK AT THIS ONE!!!
flash_back
Broj poruka : 162
Lokacija : BG
Datum upisa : 27.12.2008
