MSD ignition
MSD ignition  Empty MSD ignition
Počalji od heviarti Čet 15 Jun 2017, 22:45
Has anyone here ever tried hooking an MSD ignition to one of these with the electronic pickup in the distributor? I have an old MSD 5 hanging around, and I am considering installing it in the Yugo. Better fuel burn from multiple sparks might do a lot for the popping exhaust.
heviarti
heviarti
Broj poruka : 114
Lokacija : Emmett, Idaho USA
Datum upisa : 11.06.2017
MSD ignition  Empty Re: MSD ignition
Počalji od Milos Čet 15 Jun 2017, 23:48
Some of national Yugo racers drive MSD ignition coil, it gives about 1hp on the dyno as they say.
Broj poruka : 4104
Počalji od heviarti Pet 16 Jun 2017, 00:52
Not the coil, the module. I'm not after the horsepower so much as better combustion. I was going to put it on my '64 dodge, but I might put the 6A on it instead. The 5 is a factory replacement module not a performance module. I' m just not sure how to wire into the system. I could do it in my sleep if it was points or an HEI.
heviarti
heviarti
Broj poruka : 114
Počalji od jollyjumper Pet 16 Jun 2017, 13:55
It is bit expencive for us. People here usually use factory ignitions, or MSD coils, Digiplex ignitions...etc.
Broj poruka : 1107
Lokacija : Le
Datum upisa : 10.03.2015
Počalji od heviarti Pet 16 Jun 2017, 16:43
A little reading says the 5 doesn't like magnetic pickups, so I might not be able to install it anyway. I almost want to install a point ignition just because of the expense of the modules used in the electronic distributor.
heviarti
heviarti
Broj poruka : 114
Počalji od acer Pet 16 Jun 2017, 18:52
acer
Broj poruka : 194
Lokacija : Rijeka, hrvatska
Počalji od heviarti Pet 16 Jun 2017, 19:55
If I buy another, I'll probably go with the 6A or 6AL. I have had good results with them.
heviarti
heviarti
Broj poruka : 114
Počalji od ZAC Pet 16 Jun 2017, 21:37
Yes, the module is more expensive than Yugo.
Broj poruka : 14369
Počalji od heviarti Pet 16 Jun 2017, 21:41
I gave $50 more for the car than I'd pay for the module Wink I've seen a Yugo go for as much as $5000 for a pristine example.
heviarti
heviarti
Broj poruka : 114
Počalji od ZAC Pet 16 Jun 2017, 22:30
Where are you friend
Broj poruka : 14369
Počalji od heviarti Sub 17 Jun 2017, 00:16
United States. Idaho. Near Boise. The one for five grand is on the Internet, though
heviarti
heviarti
Broj poruka : 114
Počalji od heviarti Pon 19 Jun 2017, 06:44
https://www.google.com/amp/jalopnik.com/would-you-pay-5-500-for-a-rare-fancy-pants-1988-yugo-g-1784252967/amp
Now that I can post links, here is the $5000 example. Same model as mine, barring the color, the window louvers, and a few missing parts.
heviarti
heviarti
Broj poruka : 114
Počalji od jollyjumper Pon 19 Jun 2017, 14:34
This is really nice one. Wink I would pay that money for a Yugo in that condition. Yugo is like any Fiat or Italian car...there are few things to know about it, and it will run forever:
Oil and oil filter change must be on time. If you have 5 speed gearbox, make sure that it has enough oil, because of fifth gear.
Wait for it to worm up before pressing the throttle down, never drive it cold.
Don't be harsh with gearbox, change the gears smooth, it clicks when it is in the gear, when gearbox is good, it should go into gear by itself, you only need to push it a little bit. If you can't find the gear, dont force it. Put it in neutral and easy, it will click. When changing gears, don't change from first to second, second to third...etc., gear change is going like this:
press the clutch, put it in first, relesse the clutch and go, when you are driving, press the clutch put it in neutral, go into second from neutral, relese the clutch...etc. It is the same while changing gears up and down. Never change from second to first while driving. You can change from second to first, when you stop the car. It would look like this. You want to change: From second put in neutral, or press the clutch, stop the car, and then put it in first from neutral. First gear is used only to get the car moving or to drive it very slowly, or to drive it on hillclimb road.
It is the same with old Fiat, old Alfa Romeo, old Ferrari...etc.
Yugo has Lampredi engine (Fiat 128 engine engineered by Aurelio Lampredi-Ferrari engine designer). Yugo has revy engine, it likes to be driven fast and high revs when it is on the work temperature. That's why, Yugo is so fun to drive (driving slow car fast Smile ).
Cheers
Broj poruka : 1107
Lokacija : Le
Počalji od ZAC Pon 19 Jun 2017, 16:01
heviarti ::United States. Idaho. Near Boise. The one for five grand is on the Internet, though
I'm glad that we Yugo much appreciated in America Cheers
Primrak such as yours is here for a couple hundred dollars.
Broj poruka : 14369
Počalji od heviarti Pon 19 Jun 2017, 17:25
That's just it, very few people appreciate them. Even fewer remember them. I just think the car is pretty cool. It has a lot of good features. Before it's all done I may have to rebuild the engine. Hopefully not before I get some miles out of it. Oil looked very bad. It may get another change soon to be sure it is clean.
heviarti
heviarti
Broj poruka : 114
Počalji od jollyjumper Pon 19 Jun 2017, 18:42
I think that you would make a lot of miles...only you need to do is to clean the engine and put new oil in it. It should go fine. Don't worry. Smile
Broj poruka : 1107
Lokacija : Le
Počalji od heviarti Pon 19 Jun 2017, 18:47
Has anyone tried Lucas in these?
Are you telling me these things want to be double clutched? I drive truck, so I know how to shift without the clutch. I would never try that in the Yugo because the stations are very loose on the shifter. Because of that, I am trying to be very gentle with the gearbox. Neutral and gear stations are almost indistinguishable from one another.
heviarti
heviarti
Broj poruka : 114
Počalji od jollyjumper Pon 19 Jun 2017, 18:53
Not double cluched. But it has springs in gearbox that can be destroyed if you hardly go from speed to speed, and it makes gearbox wobble feeling. You just go from neutral into gear to be sure not to miss one, but if you are expirienced it might be ok-but this is thing to save the gearbox. Smile
indistinguishable gears-might mean that someone hard shifted it so it doesn't click when you go into gear or into neutral.
Or check elastic rubber joint that goes from shifter to gearbox under the car.
Lucas oil?
Broj poruka : 1107
Lokacija : Le
Počalji od heviarti Pon 19 Jun 2017, 19:26
Lucas additive for oil.
heviarti
heviarti
Broj poruka : 114
