Electric choke circuit
So, I have been fighting with my electric choke. According to the manual, it runs off of a relay. I pulled all the relays and fed voltage back down the wire to try to locate which wire under which relay delivers voltage to the choke. All I managed to do was light the battery lamp with the key off. Never found any connection to the relays. What is it I am missing here?
heviarti- OHV 767ccm 30ks
- Broj poruka : 114
Lokacija : Emmett, Idaho USA
Datum upisa : 11.06.2017
Re: Electric choke circuit
Mine electric choke was connected to 2nd fuse from windsheld..but mine choke was revired to run when electric idle valve,from factory it should be conectedbon alternator,w exit 7v
