Kocnice koje pasuju na Zastava automobile
Strana 1 od 10 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Sledeći
Kocnice koje pasuju na Zastava automobile Empty Kocnice koje pasuju na Zastava automobile
Počalji od Pedja taj Pon 04 Maj 2009, 03:18
Nadjoh ovo, pa mi se ucinilo korisnim. Popis automobila sa kojih se mogu skinuti kocncie i montirati na Zastave.
ALFA ROMEO
145/146 1.4i - 1.6i 16V Twin Spark 97 257x20x40
145/146 1.7i 16V 94-96 257x20x40
145/146 1.8i 16V Twin Spark 96 284x22x39
145/146 2.0i 16V Twin Spark 95 284x22x39 Zadnje svi modeli 94 240x11x40
155 1.7i - 1.8i - 2.0i Twin Spark 92-96 257x20x40
155 1.6i - 1.8i - 2.0i 16V Twin Spark 95 284x22x39
155 2.0i Turbo + 16V + Q4 - 2.5i V6 2/92-97 284x22x43
155 2.5 Turbodiesel 5/93 284x22x43
Zadnje svi modeli 92-97 240x11x40
164 2.0i Twin Spark 87-5/89 257x20x52
Zadnje 87-89 251x10x50
FIAT
BARCHETTA 1.8i 16V 95-6/95 257x20x40 Zadnje 95 240x11x40
BRAVO/A 1.6i 16V - 1.8 16V - 1.9 TD 95 257x20x40
BRAVO/A 2.0i 20V HGT 95 284x22x43
Zadnje 240x11x40
COUPE' 1.8i 16V - 2.0i 16V 96 284x22x39
COUPE' 2.0i 16V 94-6/96 284x22x39
COUPE' 2.0i 16V Turbo 94-6/95 284x22x43
Zadnje 94 240x11x40
CROMA 1.6 - 2.0 CHT - 2.0 i.e. - 2.5D 85-9/92 257x20x52
CROMA 2.0i - 2.0i 16V 93-95 257x22x51
CROMA 2.0i Turbo - 2.4 TD 85-9/88 257x20x52
CROMA 2.0i Turbo 10/88-92 257x22x51
CROMA 2.0i Turbo - 2.5i V6 93-95 284x22x43
CROMA 1.9 TD 10/88-92 257x22x51
CROMA 1.9 TD 93-95 257x22x51
CROMA 2.5 TD 10/88-95 257x22x51
MAREA 1.8i 16V - 1.9 TD 96 257x20x40
MAREA 2.0i 20V - 2.4 TDl 95 284x22x43
Zadnje 240x11x40
MULTIPLA 1.6i 16V / 105 TD 1.9 JTD 98 284x22x39
PALIO 100 16V Weekend 95-97 257x20x40
PUNTO GT 1.4 Turbo 11/93-97 257x20x40
Zadnje 240x11x40
PUNTO II 1.8 16V 99 257X22X40
Zadnje 240x11x40
SCUDO 98 284x22x39
STILO 1.8 - 2.0 01 257x22x40
STILO 2.0 01 284x22x43
TEMPRA 1.8 - 2.0 - 2.0 4x4SW - 1.9TD SW/Berl. 90-96 257x20x40
Zadnje 240x11x40
TIPO 1.8 i.e. 16V - 2.0 i.e. 90 257x20x40
TIPO 2.0 i.e. 16V 91 284x22x39
Zadnje 88-9 240x11x40
LANCIA
DEDRA 1.8 i.e. - 2.0 i.e. - 1.9TD 10/94-12/96 257x20x40
Zadnje 240x11x40
DEDRA 1.8ie 16V - 2.0 i.e. 16V 96-99 257x20x40
Zadnje 12/90-9/94 240x11x40
DEDRA 2.0 i.e.Turbo/HF/Integrale 284x22x39
Zadnje 240x11x40
DELTA (II) 1.8 16V (83kw) 96 257x20x40
DELTA (II) 1.8 16V GT/HPE (96kw) 96 284x22x39
DELTA (II) 2.0 i.e. 16V – HPE 5/93-8/95 284x22x39
DELTA HF (II) 2.0 i.e. 16V Turbo – HPE 5/93 284x22x43
DELTA (II) svi modeli zadnje 97 240x11x40
DELTA HF – Turbo 6/86-5/93 257x20x52
DELTA HF Turbo Integrale 8V - 16V 11/87-91 284x22x43
DELTA HF 4WD 86-10/87 257x20x52
LYBRA 1.8i 16V - 2.0i 20V - 1.9 JTD - 2.4 JTD 99 284x22x43.5
Zadnje 240x11x40
SOHC 1116ccm EFI 63ks
Broj poruka : 1849
Lokacija : Zrenjanin-Novi Sad
Pogledaj profil korisnika http://zafc.forumsr.com
Kocnice koje pasuju na Zastava automobile Empty Re: Kocnice koje pasuju na Zastava automobile
Počalji od bojan bor taj Pon 23 Jan 2012, 21:50
hteo bih da stavim pozadi klesta od tipa pa me interesuje da li neko ima sliku kako izgleda nosac za takav tip klesta,posto mora da se pravi za juga,ne moze originalni fiatov?
bojan bor
Broj poruka : 58
Lokacija : bor
Datum upisa : 30.12.2011
Počalji od YUgisa taj Uto 24 Jan 2012, 18:03
Kocnice koje pasuju na Zastava automobile Slika0661
Kocnice koje pasuju na Zastava automobile Slika0662
Broj poruka : 48431
Počalji od bojan bor taj Sre 25 Jan 2012, 17:06
wow!!! znaci na centralne 4 rupe ide na glavcini,a spoljne 2 klesta? ali meni ovo ne deluje tako jednostavno da se napravi. nego,jer ovo na prodaju?
bojan bor
Broj poruka : 58
Lokacija : bor
Počalji od YUgisa taj Sre 25 Jan 2012, 18:08
Da, tako je. Ne mora to toliko da bude komplikovano, evo kako je neko napravio krajnje jednostavno...
Kocnice koje pasuju na Zastava automobile Dsc03749i.th
I nije na prodaju, to je namenjeno mom Yugu Wink
Broj poruka : 48431
Počalji od bojan bor taj Čet 26 Jan 2012, 07:22
e ovo je exta.hvala puno. tako sam i ja zamisljao,samo sam hteo da potvrdim.
bojan bor
Broj poruka : 58
Lokacija : bor
Počalji od YUgisa taj Čet 26 Jan 2012, 09:04
Mada moram reci da nema smisla mnogo stavljati nazad disk kocnice bez nekog unapredjivanja prednjih kocnica posto pri jacim kocenjima ce prvo da popuste prednje kocnice pa tek onda dobosi... Prednje kocnice bi bilo dobro barem unaprediti na novi tip sa floride tj 240mm disk napred a 227mm nazad.
Naravno ja samo predpostavljam da nisi menjao prednje kocnice tj da su i dalje napred stari tip kocnica sa 227mm diskom... Ja imam npr napred 257mm ventilirajuci disk i dobos mi popusti tacno na pola puta od trenutka kada i prednje kocnice popuste tj pregreju se...
Broj poruka : 48431
Počalji od BaronNS taj Ned 19 Feb 2012, 23:54
Kocnice koje pasuju na Zastava automobile 216811_209226579095393_100000241566059_768354_7355185_n
Kocnice koje pasuju na Zastava automobile 208460_207672205917497_100000241566059_757140_5916928_n
Kocnice koje pasuju na Zastava automobile 216082_207673702584014_100000241566059_757155_164324_n
BaronNS
BaronNS
Broj poruka : 189
Datum upisa : 18.02.2012
Počalji od bukusa taj Čet 23 Feb 2012, 20:07
Barone zasto si disk stegao INBUS safom,kako leze felma zbog njega?
Broj poruka : 767
Počalji od gile u srcu taj Čet 23 Feb 2012, 20:11
zadnji diskovi takodje pasu sa tristaca Very Happy
gile u srcu
gile u srcu
Broj poruka : 17
Lokacija : zivkovci
Datum upisa : 23.02.2012
Počalji od bojan bor taj Pet 24 Feb 2012, 00:37
od cega su diskovi i klesta ako nije tajna?
bojan bor
Broj poruka : 58
Lokacija : bor
Počalji od BaronNS taj Ned 26 Feb 2012, 23:08
@bukusa - Leži dobro.
@gile - Pašu i na Pezejca.
@bojan - Čeljusti su kupljene na otpadu,od nekog Fiata,verovatno Stilo.
Kocnice koje pasuju na Zastava automobile 11
Kocnice koje pasuju na Zastava automobile 112
Kocnice koje pasuju na Zastava automobile 120
Kocnice koje pasuju na Zastava automobile 217139_207673425917375_100000241566059_757150_2243880_n-1
BaronNS
BaronNS
Broj poruka : 189
Počalji od bojan bor taj Pon 27 Feb 2012, 00:08
jesu.ja ne mogu da nadjem nigde.a diskovi?jugovi prednji?
bojan bor
Broj poruka : 58
Lokacija : bor
Počalji od Aki91 taj Pon 27 Feb 2012, 01:05
Imas nacrt sa merama za zadnje anker ploce?
Broj poruka : 1118
Datum upisa : 07.01.2010
Počalji od bojan bor taj Uto 28 Feb 2012, 22:05
pa njih pravis na licu mesta u zavisnosti od klesta koja imas.na glavcini imas promer rupa na kojima ga stezes za nju samu,a za kleta meris po klestima tj,njihovim rupama za sezanje.ne treba ti nacrt.oblik si video sa slike.
bojan bor
Broj poruka : 58
Lokacija : bor
Počalji od BaronNS taj Uto 28 Feb 2012, 23:21
@bojan - Tako je.
@Aki - Crtež je sa neta,samo je malo korigovan ugao čeljusti,zbog amotrizera.
BaronNS
BaronNS
Broj poruka : 189
Počalji od bojan bor taj Sre 29 Feb 2012, 00:31
samo mi kazi,diskovi pozadi su u stvari zastavini prednji?
bojan bor
Broj poruka : 58
Lokacija : bor
Počalji od BaronNS taj Sre 29 Feb 2012, 15:08
Kočiona sila je regulisana sa petim kočionim cilindrom koji je montiran kod glavnog.
Kocnice koje pasuju na Zastava automobile 259876_233804133304304_100000241566059_899716_1286532_n
BaronNS
BaronNS
Broj poruka : 189
Počalji od kremenko taj Ned 15 Apr 2012, 20:39
Koje kocnice od gore navednih auta pasu na yuga 1.3 efi 2000 god. bez prepravljanja.
posto sam jos u njemackoj a oni nemaju yuga u katlogu.
kremenko
kremenko
Broj poruka : 23
Lokacija : Vukovar - Freiburg
Datum upisa : 15.02.2012
Počalji od YUgisa taj Ned 15 Apr 2012, 20:48
Prednje sve pasu samo sto ako hoces u felnu od 13 inca da stavis, onda ide max disk od 240mm, ako hoces felnu od 14 inca onda mozes sve kocnice do 257mm diska da stavis a 15 inca felna ti treba za 284mm disk... Za zadnje diskove treba praviti nosac klesta...
Broj poruka : 48431
Počalji od kremenko taj Pon 16 Apr 2012, 08:38
Ja imam orginal 13 inca felge i orginal celjusti od yuga trebaju mi diskovi i pakne napred
kremenko
kremenko
Broj poruka : 23
Počalji od YUgisa taj Pon 16 Apr 2012, 08:52
Aha, ti hoces samo da zamenis diskove i plocice na tvom... To bi trebalo da je novi tip kocnica pa neka traze od Tipa neke slabije verzije... Uzmi guglaj malo, idi na Ferodo sajt pa trazi u katalog Yuga... Wink Uzmi sifru pa idi sa njom kod njih...
Broj poruka : 48431
Počalji od milinkos taj Pet 28 Sep 2012, 08:17
Ima li razlike u dobošima između starog i novog tipa zastave i koje proizvođače preporučujete, pošto se uglavnom kometariše o diskovima.
Polako prikupljam delove da zamenim stari tip kočnica za novi, pa me interesuje ima li razlike u dobošima i da li ima da se nađu samoventilirajući diskovi od 240mm da pašu na zastavu.
milinkos
Broj poruka : 60
Datum upisa : 31.01.2012
Počalji od YUgisa taj Pet 28 Sep 2012, 08:51
Koliko se ja secam ima neke razlike u naleganju na glavcinu, ali nisam siguran... Kupi Zastavin dobos.
Ventilirajuci diskovi od 240mm imas od Una Turba, naravno moraju i klesta od Una Turba.
Broj poruka : 48431
Počalji od milinkos taj Pet 28 Sep 2012, 09:26
Ja imam klešta od floride. Ima li ventilirajućih diskova koji bi odgovarali za njih.
milinkos
Broj poruka : 60
