Zac, Saradnik BMR-a za reparaciju i prodaju karburatora, anlasera, altenatora...
Strana 11 od 12 Prethodni  1, 2, 3 ... , 10, 11, 12  Sledeći
Zac, Saradnik BMR-a za reparaciju i prodaju karburatora, anlasera, altenatora...  - Page 11 Empty Re: Zac, Saradnik BMR-a za reparaciju i prodaju karburatora, anlasera, altenatora...
Počalji od ZAC taj Ned 31 Mar 2019, 00:47
Sredjena dva od tri Solexa za Ami 8 . Cetvrti ide u rashod za delove, posto mu fali jedna osovina leptira a i razlokan je skroz.
[You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.][You must be registered and logged in to see this link.]
Broj poruka : 13854
Počalji od ZAC taj Pon 01 Apr 2019, 00:35
Zavrseni...
Broj poruka : 13854
Počalji od ZAC taj Čet 18 Apr 2019, 22:16
Stigao jedan stari SOLEX F34 PBICA za Pezo 404 iz `60-tih godina.
Pravo zadovoljstvo raditi ga. Smile
Broj poruka : 13854
Počalji od ZAC taj Pon 22 Apr 2019, 21:42
Ociscen, poravnat sad samo cekam set iz Hrvatske pa da ga sklapam...
Broj poruka : 13854
Počalji od ZAC taj Sub 27 Apr 2019, 21:09
Stigao set danas, taman sam iskoristio dan pred uskrs (nije crveno slovo Wink ) da ga sklopim....
Broj poruka : 13854
Počalji od ZAC taj Uto 07 Maj 2019, 19:24
Odradjen jedan IPM za Ficu MGV-30 difuzor 21 mm
Broj poruka : 13854
Počalji od ZAC taj Sub 11 Maj 2019, 23:13
Ako nekome treba imam dobar karburator 22 mm
Broj poruka : 13854
Počalji od ZAC taj Uto 14 Maj 2019, 22:39
Sredjen jedan WEBER 32ICEV61 za Fiat UNO ... Ovaj je na prodaju...stoji na Kupindu!
Broj poruka : 13854
Počalji od ZAC taj Pet 07 Jun 2019, 22:27
WEBER 32 DGAS za Forda.
Pre i posle restauracije.
Broj poruka : 13854
Počalji od junior45 taj Pet 07 Jun 2019, 22:31
Deluje kao da pase na nase grane?
SOHC 1372ccm Turbo 134ks
Broj poruka : 27075
Počalji od ZAC taj Pet 07 Jun 2019, 22:51
Pase.
Sa ovim bi Jugo isao kao nevreme..ovaj otvara oba grla istovremeno i ainspric sprica u oba istovremeno...verovatno trosi puno.
Broj poruka : 13854
Počalji od YUgisa taj Pet 07 Jun 2019, 22:53
Nije ovo kao sa Pezejca da je malo veci raspon izmedju rupa ali da moze ako se slicuju rupe Wink
Broj poruka : 49655
Počalji od ZAC taj Pet 07 Jun 2019, 22:58
Nisam merio, ali odokativno mi lici na elektronca...raspon...jbem li ga...i donji dihtung mi deluje isti.
Broj poruka : 13854
Počalji od YUgisa taj Pet 07 Jun 2019, 23:08
Pa lici kao da je isto ali je cini mi se 6 ili 8mm veci raspon po ovoj duzoj strani, mislim nemojte me drzati za rec Very Happy
Broj poruka : 49655
Počalji od junior45 taj Pet 07 Jun 2019, 23:51
Onda jr dupli,ne dvogrli 😁
Broj poruka : 27075
Počalji od ZAC taj Čet 20 Jun 2019, 23:03
Radio sam ovih dana jedan Tomos UMO
Ful generalka...
Broj poruka : 13854
Počalji od Sultan taj Čet 20 Jun 2019, 23:07
Od kosacice?
Kako si ga sredio,Xtra... Cheers
Broj poruka : 4018
Počalji od ZAC taj Čet 20 Jun 2019, 23:15
Da ali bez farbanja...onaj moj narandzasti je kao iz fabrike..ovaj nije hteo da plati komplet restauraciju...samo generalnu...steta.
Da od kosilice... Cheers
Broj poruka : 13854
Počalji od junior45 taj Čet 20 Jun 2019, 23:59
Kakav ti je to klip? Da li je radilica menjana ili samo centrirana?
Broj poruka : 27075
Počalji od ZAC taj Pet 21 Jun 2019, 00:05
Indiski klip.
Radilica je dobra, zamenjeni samo krajnji lezajevi...na velikoj pesnici odlican.
Broj poruka : 13854
Počalji od junior45 taj Pet 21 Jun 2019, 01:37
Ne baca?
Broj poruka : 27075
Počalji od ZAC taj Pet 21 Jun 2019, 20:27
Ne, odlicna ,fabricka...baca 0.05 mm ..manje od desete.
Broj poruka : 13854
Počalji od junior45 taj Pet 21 Jun 2019, 23:43
Moja je haos,moram naci drugu
Broj poruka : 27075
Počalji od Aleko2141 taj Sub 22 Jun 2019, 22:21
Nađite od samare karburator, menanicki oba grla i ajspric u oba grla, aleko ide ko lud sa njim
Broj poruka : 821
Počalji od junior45 taj Ned 23 Jun 2019, 00:39
Ako vec mora karb,nek bude elektronac 😂  weberi imaju jednu anspric diznu,ali je breg koji pogoni duplo veci kad se otvori drugo grlo,tako da je duplo vise goriva kad se otvara,tako da je isto kao i da ima dva
Broj poruka : 27075
